Is there a attachment that I can pull behind that will take some of the bumps & irregular spots out of my 2 acre yard. It is so jarring just to mow it. My ground consists of Clay & some rock. I have a Four Wheel ATV & a 18 HP Mower to do the pulling.
Lawn smoothing
Usually right at the spring thaw is the best time to use a lawn roller for that purpose. The ground is in a pretty sponge-like state and is easily molded. You may still meet with some success yet, depends on how 'fluid' the dirt is about now.....A rent-all shop should have what you need. Get something that has a larger diameter and about as narrow as you can get. That will give more weight per sq inch, and that's about what you need if the ground is relativley dry.
