planting grass seed
  • redbone
    • Nov 2005
    • 12
    planting grass seed
    Hi all
    What of fertilizer should I mix with grass seed before sowing?
    Your input is welcome
    Redbone
    Maybe tomorrow... but not today
  • jtfoxman
    • Jan 2005
    • 150
    The fertilizer to use is called Starter Fertilizer. It usually has this printed on the label. I know Scott's has this stated on its bag since I just recently purchased some.
    Jtfoxman
      Here is an old trick that will help stimulate germination of your grass seed. Place the seed in your freezer for about 4 to 5 days before sowing.
      The freezing simulates the wintering over of seed and aids in cracking the hull of the seeds to permit moisture to enter and begin the germination process.
      I first learned of this from my grandfather when i was a kid on the farm, but recently I read a report on the Ohio State University Agricultural Extension service that confirms it works.
      • wmlbrn
        • May 2007
        • 10
        is there any benefit to applying a layer of peat moss after i seed. Allow the water to sit better?
        Manitoba Progressive Conservatives
        Manitoba NDP
        Manitoba Liberals
        Vote Manitoba
        Gary Doer
          I don't see any good in using peat moss other than enriching the soil or breaking up hard soils into a workable mixture. my dad always used to put peat moss on our lawn every spring - I don't know why - I only see it as a ground cover in flowering beds. Bark mulch does the same thing but you wouldn't use this on your lawn.
