Avoiding paint on walls when painting trim and baseboards
  • Avoiding paint on walls when painting trim and baseboards
    What’s the best method for painting trim and baseboards cleanly without getting paint on the adjacent walls?
    Thanks!
    A good way to paint trim and baseboards cleanly is to use painter’s tape along the edges to protect the walls. Using an angled brush and painting slowly helps too. Another option is carefully “cutting in” (painting the edges by hand with a brush) without tape for a neat finish.
      What works well for painting the corners where the baseboard and wall come together?
        For painting the corners where the baseboard meets the wall, an angled brush provides better control. Gently dragging the brush along the corner helps prevent overlap onto the wall. Painter's tape can also be useful for a cleaner line, but it’s important to press it down firmly to avoid paint seeping underneath. Painting in small sections and working carefully usually results in a neater finish.
          Is there a certain type of paint finish that works well on trim?​
            Semi-gloss and satin finishes work well for trim and baseboards. These finishes are durable and easier to clean compared to flat paint. They also provide a subtle shine that highlights the trim without being too glossy.
              One last thing. Are there specific brush types that work better for trim work?
                Angled sash brushes are a good choice for trim work because they provide better control and make it easier to paint along edges and corners. Brushes with fine, synthetic bristles tend to give a smoother finish and work well with water-based paints, which are commonly used on trim. A brush that's 1 to 2½ inches wide is usually the right size for most baseboards and trim areas, helping with both precision and coverage.
                  Helpful info!
