Painting heating pipe?
  • dkpbxman
    • Oct 2005
    • 136
    I'm going to need to re-paint the floor to ceiling cast iron steam pipe in my Mom's bathroom. I have no idea when it was last done but the paint now is completely flaking and falling off.
    Do I need to use special "heat" paint or will regular paint do the job?
    Thanks,
    Dan
    regular paint will flake off. those high heat paints used on engine manifolds will work.
    • Trim Plus
      • Dec 2009
      • 7
      Hi dkpbxman'
      I would guess the best thing to do is get a bare metal conditioner for the type of metal your pipes are made of and apply. Than use a metal primer intended for same as previously mentioned. Than apply top coat. The paint HayZee518 mentioned I really don't think is necessary because I don't believe your pipes are getting as hot as engine manifolds.
      • homemaker
        • Jul 2012
        • 7
        I think if you are painting your home again and you need not to paint with full specs you just need a bit improment of all.
