Repainting
  • Annahmed
    • 223
    Repainting
    Hello everyone! What's the best way to remove old, peeling paint from exterior wood siding before repainting?
    Thanks!
  • FatimaandAhmed
    • 343
    Hello!
    To remove old, peeling paint from wood siding, start by checking the wood to make sure it's in good shape—fix any damaged spots first. Then, use a scraper or putty knife to gently scrape away any loose paint, being careful not to damage the wood. After scraping, go over the area with a wire brush to remove any leftover paint flakes and smooth things out. If some areas are tough to clean, you might need a chemical paint remover, but be sure to follow safety instructions when using it.
    For a cleaner surface, you can use a pressure washer, but keep the pressure low to avoid damaging the wood. Let the wood dry completely. If any bare wood is showing, apply a primer to help the new paint stick better and to protect the wood. Once the primer is dry, lightly sand the surface to make it smooth before you start painting. This process will help the new paint go on smoothly and last a long time!​
    • Annahmed
      • 223
      Thank you for this in detail.
