glossy latex finish to matte finish
  • machinist
    Moderator
    • 386
    Hi. Can someone provide information on how to properly transition from a glossy latex finish to a matte finish on walls?
  • Downaski
    • 409
    Hi machinist!
    Here's how to go about it properly:
    First, you'll need to prepare the glossy surface. Start by cleaning the walls thoroughly with a degreaser or all-purpose cleaner to remove any dirt, oils, or residue. This is crucial for proper adhesion of the new paint. Once clean and dry, lightly sand the glossy surface. You're not trying to remove all the gloss, just scuff it up enough to give the new paint something to grip onto. Use a fine-grit sandpaper (around 120-180 grit) and sand lightly by hand or with a pole sander. After sanding, wipe down the walls with a tack cloth to remove all dust.
    Next, apply a bonding primer. This is a key step when going from glossy to matte. A good bonding primer will stick to the old glossy surface and provide a great base for your new matte paint. Allow the primer to dry completely according to the manufacturer's instructions. When it comes to choosing your matte paint, opt for a high-quality product. Cheaper paints often don't cover as well, especially when going over a darker or glossier finish. You'll likely need two coats of matte paint for full, even coverage. Apply your matte paint using a roller for larger areas and a brush for cutting in around edges and corners. Work in small sections and maintain a wet edge to avoid lap marks. Let the first coat dry completely before applying the second.
    One thing to keep in mind: matte finishes, while great for hiding imperfections, are generally less durable and harder to clean than glossy finishes. Consider using a matte paint that's marketed as washable or scrubbable for high-traffic areas. Lastly, be patient. Allow plenty of drying time between coats and after the final coat. Proper drying time ensures the best finish and durability for your new matte walls.
    Would you like more details on any part of this process, or do you have any specific questions about the transition?​
    • machinist
      Moderator
      • 386
      Nope, thank you for the detailed answer. Really helpful!
      • Downaski
        • 409
        You're welcome!
