Spray paints for wood
  • Annahmed
    • 223
    Does anyone have recommendations for spray paints that work well on wood?
  • DarkKnight
    • 328
    For spray painting wood, here are a few solid options that work really well:
    1. Rust-Oleum Universal All Surface Spray Paint – It's great for wood and other surfaces, super durable, and comes in a lot of finishes like satin and gloss.
    2. Krylon ColorMaster – Known for good coverage and quick drying, and it comes in tons of colors and finishes.
    3. Valspar Premium Enamel Spray Paint – This one’s awesome if you want a smooth, long-lasting finish, especially for projects that need to hold up well.
    4. Montana Gold Spray Paint – More for creative projects, but it gives a really nice, vibrant finish on wood.
    If the wood’s untreated, it’s a good idea to sand it lightly and maybe prime it before painting to get the best result. What are you working on, by the way?​
    • Annahmed
      • 223
      Thanks for the suggestions! I’m actually thinking about changing the color of my bed. I’m not entirely sure, but I think some parts of it are made of solid wood. Do you think sanding and priming would be necessary for a project like that? Also, would one of these spray paints work well for furniture, or is there something else you’d recommend for a smooth, durable finish?
      • DarkKnight
        • 328
        You're welcome! Changing the color of your bed sounds like a great project! If the bed is made of solid wood or even has a wood veneer, sanding is usually a good idea. It helps smooth out any imperfections and gives the paint a surface to adhere to. Priming is also essential, especially if you’re covering a dark finish or want a long-lasting result. As for spray paint, it can work well for furniture, but for a really smooth and durable finish, consider using a spray paint specifically designed for wood or furniture. Alternatively, a quality brush-on enamel or chalk paint can give excellent results, too. Let me know if you need any further help.
        • Annahmed
          • 223
          Thanks so much for the great advice! My bed was custom-built, and it has a golden-toned finish. Some parts of the surface aren't as smooth as I'd like, which is bothering me. What type of paint would you recommend for a smooth, durable finish, considering the golden color?
          • DarkKnight
            • 328
            You're welcome. To get a smooth and durable finish for your bed while maintaining the golden tone, start by prepping the surface properly. Lightly sand it using medium-grit sandpaper to smooth out imperfections, and then finish with a finer grit for a flawless base. Next, apply a high-quality bonding primer to ensure the paint adheres well, especially if the bed has a glossy or varnished finish. For the paint itself, metallic or oil-based enamel paint would be great options. They're durable and provide a sleek finish that can complement the golden color beautifully. Once the paint is dry, seal it with a clear polyurethane or polycrylic topcoat for added protection and a long-lasting, polished look. This method will leave your bed looking smooth and refreshed, with the golden tone shining through.
            • Annahmed
              • 223
              That’s a great method! I like the idea of using metallic or oil-based enamel paint for a polished finish. How many coats of paint and topcoat would you recommend for the best durability?
              • DarkKnight
                • 328
                I’d recommend applying 2-3 light coats of paint. Make sure to let each coat dry completely before applying the next to avoid drips and ensure an even finish. After the paint, a clear topcoat is essential for protection and shine. Apply 2 coats of a high-quality clear spray topcoat (like polyurethane or lacquer) for added durability. Again, let each layer dry fully and lightly sand with fine-grit sandpaper (like 320-grit) between coats for a smooth, polished finish.
                • Downaski
                  • 409
                  That sounds like a solid approach! I totally agree that letting each coat dry completely is key to avoiding any issues.
                  Also, wipe down the surface with a tack cloth before start to ensure there’s no dust or debris that could affect the finish. ​
                  • Annahmed
                    • 223
                    Thank you for the help!
