When Is the Right Time to Add Gutter Guards?
  • Downaski
    • 409
    For homes without gutter guards, is summer a good time to install them, or is it better to wait until fall when leaves become an issue?
  • DarkKnight
    • 328
    Hi there!
    Summer is actually a great time to install gutter guards. The weather is usually dry, which makes the job easier and safer, and you’ll have everything in place before the leaves start falling in the fall. Waiting until autumn can be tricky because by then, gutters may already be clogging up. Getting it done in summer means less hassle later and one less thing to worry about when the seasons change.
    Hope that helps!
    • Downaski
      • 409
      Thanks! Are there certain types of gutter guards that work better for homes surrounded by trees? Also, is installing them something a homeowner can typically do themselves, or is it better left to a pro?
      • DarkKnight
        • 328
        If your home is surrounded by trees, especially ones that drop a lot of leaves or needles like maples or pines, some gutter guard types perform better than others. Micro-mesh guards are often a good choice because they block even small debris while still allowing water to pass through. Surface tension or reverse-curve styles can also work well, but they tend to be more expensive and may require professional installation.
        As for whether it's a DIY job, many gutter guards are made for easy installation, especially the snap-in or drop-in types that fit standard gutters. But if your gutters are hard to reach, your roof is steep, or you're going with a more advanced system, it might be safer and more effective to hire a pro.
        • Downaski
          • 409
          Which types are least likely to clog or need cleaning later?
          • DarkKnight
            • 328
            Micro-mesh gutter guards are usually the least likely to clog because they block even small debris like pine needles and shingle grit. They're low maintenance and generally don’t need much cleaning if installed well. Solid surface or reverse-curve types also resist clogging, but they can be harder to install and may still let some smaller stuff through.
            That said, it’s still a good idea to check them occasionally just in case.
            • Downaski
              • 409
              Appreciate all the tips! Sounds like micro-mesh might be the way to go. Thanks again!
