Hello forum,
This is officially my first post on this forum. Before I ask for any solutions to my problem, allow me to give some background info/history:
Problem 1:
- About 15 years ago, my house began sinking. It was eventually jacked up and raised. Unfortunately, my dad built a patio in the backyard before the house was raised. As the contractor raised the house, the patio stayed as is and eventually connected back to the rear of the house. Presently, when it rains here in southern Louisiana, the backyard tends to fill with a lot of water. What I am proposing to do is to establish a drainage system from the backyard to the front street. Here's my question: How do I determine the difference in height from the backyard to the front. What I would like to do is connect a catch basin from the patio gutters and connect it to PVC towards the front where it finally drains. The distance from where the catch basin would be in the back to the front would be about 100 feet. Normally, drainage occurs from back to front, but since the house was raised, not enough fill dirt was was placed back into the backyard. So now, rainwater tends to collect in the backyard.
Problem 2:
When the contractors jacked up the house, they tunneled their way through beneath the foundation. When work was finished, they did not fill underneath the house with soil. What they did instead was "skirt" around the foundation with a black tarp, connect the tarp to the foundation then filled in dirt around the house. So now, we have a 3 foot void beneath the house. As time went on, the black tarp eventually tore, allowing sourrounding fill to erode underneath the house. As this happened, guess where the rainwater eventually drained to? Yes, underneath the house. So when a heavy rain should occur, the void underneath the house will fill with water. Once filled, it will begin to flow back into the backyard. This is where I want to start a drainage system, but I believe the backyard may be about level with the front. What's everyone's best advice to determine the difference in height from back to front? I've tried using string and a line level, but I think the difference is too great to get an accurate level.
Any and all advice is much appreciated. Thank you.
Regards,
RFerrer
Problem 1:
Problem 2:
Regards,
RFerrer
