Asus A 15 wireless disappearing issue.. Help!
Asus A15
As I said earlier, the issue is already highlighted by many users. There are two possible solutions, one is related to the software the other the hardware. I remember seeing a modified driver for this card in a forum, you will have to search it. Other issue is related to how Asus has placed the WIFI card just underneath the SSD. As you use your laptop and your SSD heats up, it affects your WIFI card and it shuts down. Make sure you turn off all the power saving stuff from MyASUS. So here is what I should suggest you should try:
First make sure all your drivers are updated, if the issue persists try the modified driver. If the issue is not fixed even after changing the drivers, try installing the SSD to another slot. In some Asus A15 models you get another SSD slot. If you require any further assistance please let us know.Comment
