water channel over outbuilding door
  • supadart
    • Dec 2004
    • 21
    Hello,
    I have a detached garage that I usually spend more time in than I do the house. It does not have gutters on it. When it rains -even lightly -it's impossible not to get soaked when exiting the building.
    I've seen L-shaped brackets or channels (don't know what to call them) that can be placed over doorways to direct most of the runoff from that area.
    Can someone give me some info on where I can find a section of this and how I would go about attaching to the roof above the door?
    Thanks. -Gary
    Contact any local siding installer or sheet metal shop and they could custom break those for you in a few minutes.
    • supadart
      • Dec 2004
      • 21
      I have a nice section of 18 guage stainless that is L-shaped. Would that work? I would probably drill some holes through it for the nails, but how would I go about attaching it to the roof so it doesn't cause a leak?
      Thanks. -Gary
        You could probably use the U shaped metal, however I would prefer to make a drip edge flashing with a water channel.
        • Lindsay
          • Feb 2005
          The best is weld!
            In all probability if the rain channels were formed at a sheetmetal shop they would be made of galvanized sheet metal. While soldering galvanized sheet metal is fairly easy, welding would not be a good idea.
            Welding any metal with a galvanized coating will release toxic fumes from the zinc and should only be attempted by experienced welders who have the proper respirators and safety equipment.
