the pilot light wont't stay on, have to constant relight after it heats up
water heater
ok, first thing that comes to mind is pressure. does the pilot light make any noise sort of like the whooshing from a propane torch tip? If it does then the regulator is set too high. The flame should sort of just dance on the tip of the pilot orifice. Next will be the air/gas ratio. Too much gas the flame tips will be yellow or orange. Natural gas or propane should be a nice blue color when the air/gas ratio is right.Comment
the regulator is something that isn't field adjustable. natural gas is adjusted for a 4-5 in water column and propane is a 10 inch water column. the main valve mixes air with the gas to give a burnable flame. the pilot flame is of a very low pressure so it just sits there burning. the force of the air/gas mixture that comes out of the main burner shouldn't be that great that it blows out the pilot flame. another thing that may have something to do with it is a high velocity draft through your chimney. the draft is nothing more than a vacuum up through your stack.Comment
