water heater
  • champlain
    • Jan 2007
    • 4
    water heater
    the pilot light wont't stay on, have to constant relight after it heats up
    • 8747
    Natural gas or propane? Doesn't really matter - When you press the pilot light button and release it does the pilot stay lit?
    • champlain
      • Jan 2007
      • 4
      pilot liy
      yes it stay on it goes out when it is reheating
      • champlain
        • Jan 2007
        • 4
          • 8747
          ok, first thing that comes to mind is pressure. does the pilot light make any noise sort of like the whooshing from a propane torch tip? If it does then the regulator is set too high. The flame should sort of just dance on the tip of the pilot orifice. Next will be the air/gas ratio. Too much gas the flame tips will be yellow or orange. Natural gas or propane should be a nice blue color when the air/gas ratio is right.
          • champlain
            • Jan 2007
            • 4
            Pilot Lit
            Ok Know How Do You Adjust The Regulator, Because Somtimes When I Watch The Flames It Turns Orange Thanks For Your Reply
              • 8747
              the regulator is something that isn't field adjustable. natural gas is adjusted for a 4-5 in water column and propane is a 10 inch water column. the main valve mixes air with the gas to give a burnable flame. the pilot flame is of a very low pressure so it just sits there burning. the force of the air/gas mixture that comes out of the main burner shouldn't be that great that it blows out the pilot flame. another thing that may have something to do with it is a high velocity draft through your chimney. the draft is nothing more than a vacuum up through your stack.
