I do a lot of remodeling etc....but have made many countertops of all sizes and shapes with formica/wilsonart etc (laminates). I usually use oak or pine for the edgings and backsplash caps. I can give anyone step by step instructions how to make to make theirs...just post or e-mail. There's actually only a couple real critical steps in the process that can cause catastrophe. This can all be done with a skill saw....miter saw...drill....router....and a couple router bits. If you don't have a brad nailer then would need a nail set as well. To make your own custom backsplash cap you would need a table saw but many mouldings can be found that would work just as well.
Laminated countertops
"If a stain develops on the surface, wipe it away with soap and water or glass cleaner. If a stain doesn't respond to soap and water, and your surface has a matte finish, apply an abrasive cleanser and buff with a Scotch-BriteĀ® pad using a circular motion. The same technique can be used for cigarette burns, minor cuts and scratches. For a gloss finish, you should contact dealer or fabricator before attempting repairs. (See sink care & maintenance.)"
[8]Comment
wow...an abrasive cleaner?.......I've had some luck with the laminate scratch/seam filler if you can get it to match up on color. I think they are telling you basically with that scotch pad that it "sands" the scratches out....if you have anything other than a dull matte finish I would think the surface would look dulled in that area. Let me know if it works though...interested to know.Comment
Resurfacing Laminate Countertopos
I have dark grey laminate countertops and I want to change them. I was wondering if anyone has done this. I don't want laminate anymore. I would like to cover it with tile pieces, glass pieces or something else. I like the sheets that you can buy with all the pieces on them. Can anyone direct me to a site or someone who has done this with the step by step instructions for a do-it-yourselfer?
Thanks
