finding gas shut off valve
  • jrvhunter
    • Feb 2011
    i need to remove an old gas stove out of a house and cap off the old gas line. the stove is built into the wall. Removing the stove shouldn't be a problem. i just need to know if the shutoff valve is behind the stove itself and need to pull the stove out first.
    thank you
    • 8747
    be very careful and see if its hard piped. if it is then the pipe would be in the basement with a shutoff. if there is a flex line it would be coiled up behind the range.
    • jrvhunter
      • Feb 2011
      alright thanks. the house dose not have a basement, however there is an utility room right next to it, ill check in there for a hard pipe the next time i get to the house.
      thank you!
