Hi All - I'm new to the forum and I need help with my central vac.
I have a Nu Tone CV 353. No matter what inlet I plug it into, I get almost no suction on the hose end. The canister in the garage seems to be working however as it turns on at normal power, the air blower seems to be pulling through and blowing out air fine.
I assumed this indicated that the hose was clogged, but I ran a garden hose all the way through, didn't get a clog out, then tried again with no luck.
Could there be an obstruction somewhere in the pipes between the inlets and the canister? I haven't had a central vac before, so i'm at a loss!
