Kenmore Dryer
  • onebudjack
    • Mar 2011
    Kenmore Dryer
    it runs and it heats up and truns fine but it dose not blow air out the vent and the cloth are not dry the elemnt dose heat up the vent is clear
    model 110- 8687800
    model 110- 8687800
    That model number is incorrect. It appears to be missing a digit: 11086878_00
    Please double check it.
    the vent is clear
    Is the vent is clear all the way from the dryer to the outdoors or just from the dryer to the wall??
    The only things that should prevent the dryer from blowing is a problem with the venting or vent cover on the outside of the house or a problem with the blower fan, maybe loose on the motor shaft or broken. When it fails it make A LOT of noise which would usually be noticed while in use.
    LINK > Kenmore 110.86878800 Blower Fan
    • onebudjack
      • Mar 2011
        Originally posted by onebudjack
        [the corrected model number is] 110-86874800
        That model uses the same blower fan as linked above. The rest of my reply applies as well.
        What about the venting question I asked? Is it clear all the way from the dryer to the outdoors?
