Hello All:
On my GE Profile side-by-side fridge (model PCF25MGWA), ice builds up on the evaporator coils in the fridge compartment. Eventually, the entire evap coil assembly is frozen solid and the evap fan is unable to circulate air even though it's running, leading to increased temperatures in the fridge compartment. If I allow the ice to thaw, the fridge starts working normally but after a couple of days the ice starts to build-up again. I'm not sure what the defrosting mechanism for this fridge is but it seems to be broken. I took the evap assembly apart and I saw some sort of probe (pic. attached) inserted into an aluminum block that is zip-tied to the evap coils. Is this a temperature probe, or, is this some sort of heating element ?
FWIW, the freezer section seems to be working just fine and there's no ice build-up on the freezer section's evap coils.
Any help/insight would be appreciated.
Thanks in advance
Thanks in advance
