humming noise from GE fridge
  • sharon
    • Oct 2011
    Have a GE GTS18KBM fridge (about 10 yrs old) that runs well but just started to make a loud humming noise (sounds like it's coming from the freezer) when the fan (?) or whatever else can hum, is running. Serious? Or just an annoyance? Is there an easy, inexpensive fix? Thanks!
    As I replied to your other forum posting...
    : Have a GE GTS18KBM
    That model number is incomplete. Did you get it right off the appliance's model and serial number tag?
    : working fine, that just started making a loud
    : humming noise (sounds like it's coming from
    : the freezer), when the fan (?) or whatever
    : is running.
    It could be a problem with the fan motor (see the link below). It is a common failure point.
    LINK > GE GTS18KBMARWW Freezer Fan Motor
    : Is this serious or just an annoyance?
    If the motor bearing are responsible, the motor will probably fail eventually and may result in food loss. If left operating for a long time with a failed motor more serious damage can occur. You should probably consider replacing it sooner rather than later.
    : Is there an easy, inexpensive fix?
    You're lucky, yours looks to be an older design where just replacing the motor may be necessary. On newer designs that have an electronic control, that control can be responsible for fan motor noises which can be expensive to replace. Just replacing the motor is usually fairly simple.
    Appliance411.com
    • sharon
      • Oct 2011
      Sorry, Dan. Didn't realize you troll multiple sites!
      I figured the more sites I posted on, the more responses, suggestions I'd get.
