GE Dryer (model DBXR463ED2WW) does not cycle to lower temp
  • Back40
    • Apr 2011
    • 10
    My GE dryer (model DBXR463ED2WW) drys at a high temp even when the temp selector is set to a low temp. Is this a thermostat prob? I have searched and found a high limit thermo and cycling thermo. Do I need to replace both of just one or is this prob from something all together different? Thanks in advance for your feedback!
    Last edited by Back40; 11-22-2011, 05:55 AM. Reason: Problem described incorrectly
  • Dan O.
    • Sep 2003
    • 2167
    Originally posted by Back40
    My GE dryer is not switching to a lower temp in the cycle.
    What do you mean by that? What exactly you are expecting should happen??
    Appliance411.com
    • Back40
      • Apr 2011
      • 10
      Hi Dan, apologize for describing the problem incorrectly. I am getting this info 2nd hand. The problem is that the dryer drys at a high temp even when the temp selector is set to low. Thanks again for your feedback!
      • Dan O.
        • Sep 2003
        • 2167
        It is the control thermostat responsible for controlling operating temperatures. When set on a lower heat setting a 'bias heater' inside the thermostat is powered lowering the temperature it operates at resulting in cooler drying.
        LINK > Dryer thermostats, safeties and sensors
        If the dryer only operates as if on 'hi' that thermostat could be defective or the heat selector switch could be.
        LINK > GE DBXR463ED2WW Control Thermostat
        LINK > DBXR463ED2WW Heat Selector Switch
        The bias heater terminals should be able to be tested for resistance to see if it was defective. It should have some resistance. If it showed infinite resistance the thermostat heater would be defective and the dryer would only dryer at the hottest temperature.
        JFYI
        Appliance411.com
        • Back40
          • Apr 2011
          • 10
          Thanks Dan. However, when I search on the model I also see the following cycling thermostat (Manufacturer Number WE4M216). Just want to confirm the correct thermostat before ordering.
          Also, I have had limited experience using a multi tester. How would I go about testing the Heat Selector Switch?
          Thanks again for your guidance!
          • Dan O.
            • Sep 2003
            • 2167
            That one is mounted on the exhaust output. I don't know if it is used for the main temperature control but its bias heater could be tested as well. It's a failure of that part of the thermostat which would prevent different temperatures from being used.
            I can't tell you exactly. Someone would need to look at the appliance's wiring diagram to see if its switching matrix is listed and then test each set of contacts one at a time while the switch was changed from setting to setting. There might be test procedures listed in the 'tech sheet' which should accompany the unit's wiring diagram.
            LINK > How do I test for continuity?
            There may also be resister(s) connected in the wiring to those switch terminals which might need to be tested as well, if not internal to the switch itself.
            JFYI
            Appliance411.com
