Oven preheat temperature
  • dfitz3390
    • Oct 2010
    • 135
    Dan i have a question, the average electric range with the oven set at 350 and it reaches pre heat temp. what should the temp range be as the oven continues to operate ? the one in question, set at 350 runs from 350 to 400 stops and returns to 350 should the temp get to 400 when its set for 350 ?
    thanks Dan
    I separated your message into a new thread to keep messages threads on just a single topic.
    Electric ovens usually have a wider temperature differential than gas ovens do. +/- 20 deg. F would not be out of question. Eg. When set to 350, the temp could rise to 370 and then drop to 330 before starting to heat again. I wouldn't expect a gas oven to be more than +/- 10 deg F.
    Measuring the differential should be done after the oven has reached full temperature and the control has cycled at least twice on its own. I don't know how hot it would get right after the initial preheat but I think 400 would be too hot when only set to 350 but as long as the oven cycling temperature is within specs, I wouldn't worry about the temperature only after preheat.
    Appliance411.com
    • dfitz3390
      • Oct 2010
      • 135
      Dan , i found that im able to adjust the temp so ill try that before changing the sensor
      thanks
      Dan
