wont make ice. what can I look at? Thank you in advance.ant
freezer wont male ice. frigidaire glh566ejsbo
You can read about possibilities for cooling problems on refrigerators at the following link. Each would need to be looked into until the cause in your case is found.Originally posted by adamantwont make ice. what can I look at?
LINK > My frost free refrigerator is not cooling properly. What might be the problem?
If you have any specific questions afterward, post them here and we'll try to answer them.
Appliance411.com
.Comment
For best ice production of an automatic icemaker the freezer temp should be between -2 and -5 deg. Ftemp zero.
You might want to try setting the temperature a bit colder or making sure it is cooling properly. Has anyone checked and/or thoroughly cleaned the fridge's condenser recently?
Appliance411.com
=D~~~~~~Comment
Channel: Appliances
