freezer wont male ice. frigidaire glh566ejsbo
  • freezer wont male ice. frigidaire glh566ejsbo
    wont make ice. what can I look at? Thank you in advance.ant
    ice
    what's the temperature of your freezer?
      You can read about possibilities for cooling problems on refrigerators at the following link. Each would need to be looked into until the cause in your case is found.
      LINK > My frost free refrigerator is not cooling properly. What might be the problem?
      If you have any specific questions afterward, post them here and we'll try to answer them.
      Appliance411.com
        temp zero.. I took out the tray last night and installed it back and this morning there was some ice in the bin..
          temp zero.
          For best ice production of an automatic icemaker the freezer temp should be between -2 and -5 deg. F
          You might want to try setting the temperature a bit colder or making sure it is cooling properly. Has anyone checked and/or thoroughly cleaned the fridge's condenser recently?
          JMO
          Appliance411.com
