Samsung fridge fan noise
  • mamamia1
    • Apr 2014
    We have this 7 month old French-door fridge that works perfectly otherwise, but it emits some whirling noise, like a fan's blades touching something, and it comes from the bottom-back, when the compressor is at work.
    What's weird about it is, when I open a door, or the freezer door — the noise will subside or get quieter, or even when I ROCK the fridge, the noise will subside or change, as if something is loose there... We had 3 technician visits already, last one replaced the Condenser fan, which fixed the problem for a couple days, but then the noise came back...
    What's going on?.... Thanks...
  • dfitz3390
    • Oct 2010
    • 135
    For the specific model, Dan O. is probably better to ask but it may be your evaporator fan inside the unit itself. it could possibly have ice build up on the evaporator and the fan blade is hitting it.
    • mamamia1
      • Apr 2014
      Interestingly, I searched online, and the only complaints about fan noises are connected with the Evaporator and ice buildup....I will mention it to the technician heading our home tomorrow....
      • dfitz3390
        • Oct 2010
        • 135
        well good luck, hopefully it isnt an expensive part
        • mamamia1
          • Apr 2014
          Well, it's still under warranty, so I don't care about that aspect.... It's just ANNOYING....
