Whirlpool Garbage Disposal
  • mindmalfunction
    • May 2004
    I recently purchased a home with a double sink and a whirlpool garbage disposal. The disposal has not worked since I moved in. I have never used a disposal before - I may be doing something wrong. I flicked the switch on and the disposal makes a "hummmm" sound. Is there another "on" switch? I decided not to use the disposal and ignored it. Recently, the sink with the garbage disposal stopped draining. I used a plunger and the sink slowly drains. Now, my dishwasher is backing up into the sink - while my dishes have food particals on them. How do I stop this? I looked under the sink and pushed a red button, thinking I needed to reset the garbage disposal. Nope. No luck! I need help!
  • irregularjoe
    • Nov 2003
    • 176
    There is usually a hex shaped key hole in the bottom of the disposal. You put the key into it and manually turn it back and forth, freeing up the disposal.
    I suspect that the drain from the disposal to the tee is clogged up. You have to disamemble the drain to clean it out.
