nickel stuck in garbage disposal
  • didi768
    • Jun 2003
    Please tell me there is a way to get this out without calling a plumber. I can't get the gears to move in the hole, it moved at first but now NADA! Can it be taken apart by my husband?
    Help!!! Having a really bad day.
    Thanks!
    Dianne[V]
  • Troy
    Moderator
    • Jul 2002
    • 576
    I think your husband can handle it. Can you see the nickel?
    Try
    • N8FLY
      • Dec 2003
      Hello all,
      Today is my first time on the site. I found a thread that matches the problem I am having. It's not a "nickel" though. I can see a metal flip-top of a soda-can wedged in the side of my disposal when I shine my flashlight down the drain. I can grab onto it with a pair of needlenose pliers and pull but it won't budge. I'm a pretty strong guy and am pulling hard. I don't want to break anything and it seems to have gotten hooked on something below! Do I need to take the disposal apart? When I use the allen wrench to turn the disposal, it turns freely until it gets to a certain point in each revolution where it binds and I can feel something scraping. When I turn the wall switch on, the disposal binds, hums, etc. If I need to drop the disposal from the sink, can someone give me the basic steps in sequence order (how to dismantle the thing) so I don't screw this up.
      Thanks!
      Nate
      • N8FLY
        • Dec 2003
        Disregard the above post... I disconnected the disposal from the drain so I could get a better look inside where the soda can top was stuck and was then able to muscle it out with needlenose pliers piece by piece. I put it all back together a it works like a champ.
        Nate
