I have an indesit washing machine and it will not fill up with water. When I set it to the required setting it will put water into the tray with the powder and softener, but then run it straight back out of the waste pipe. It will just stay on that setting continously putting water in the tray and back out of the waste pipe!!! If I change the setting it manually it will spin the drum etc, but no water. This machine worked fine in my old house, but since we moved we have had this problem.
Also the waste pipe that goes outside is quite flat to the kicthen floor, and on not much of an angle. Would that make any difference?
I really need to get this sorted asap, as i am starting to smell like a tramp!!!!
Thanks in advance.
Thanks in advance.
