Hi everyone!
I know that this is an often discussed subject and trust me, I have looked all over the internet for a solution, but I can´t fix my washing machine. [B)]
Here is the problem: It will only slowly drain/pump out the water after a washing cycle. The pump has been replaced recently and is working normally, so a blocked hose/pipe seems to be the logical explanation.
*) I have completely removed the pump with all attached hoses and pipes and checked all for any blockages. --> No result.
*) I have washed out the drum, so there is nothing blocking the draining hole which connects the hose that feeds the pump. --> No result
*) I have used a mild anti blocking agent to remove any possible build up of hair/washing powder. --> No result
This problem first appeared after moving the machine to a new house. It was working fine before.
Sometimes, when the water level inside the machine is low, the pump manages to pump out the water in a normal way, but normally there is only a trickle of water coming out of the draining hose.
Does anyone have any clues? What have I missed? [?]
Oh yeah, the washing machine is a Bosch WFK 2431 and is only 3 years old.
Thanks in advance!
The Dude!
Thanks in advance!
The Dude!
