Does anyone know how to lift the top of a Frigidare gas range? The front burners on my range are very weak, and I'm sure there is some sort of an adjustment inside ... if I could get inside. Has anyone else had this problem?
Frigidare range
There are no adjustments on the burners. The gas is regulated by the individual burner controls and the gas is then transported to the burner by a cross tube.
The gas controls, which are directly behind the burner control knob do have adjustments but they are very touchy to work with and should only be adjusted by a trained gas appliance service technician.
