Thanks! It worked for me!
quote:Originally posted by Maintenance Man
Hi angel_in_hiding01850
If the Disposal won't drain then you either have a blockage in the lower part of the disposal(drain chamber) or (usually) the drain line from the Disposal is blocked.
If you have a double sink then the pipe from the Disposal to the drainer side is blocked. The pipe can be cleaned out with a sink plunger.
Try this:
1 Remove the Dishwasher vent cover (the chrome or gold plug on the sink top) to expose the plastic vent, cover this with a latex glove and replace the cover.
2 Plug the drainer side of the sink with either the stopper or wet rags held in place.
3 Quarter fill the Disposal side of the sink with water. Now get your plunger ready, next flip the Disposal on and use the plunger to pump like crazy. The combined efforts of the suction from the Disposal and the plunger is usually enough to break the blockege in the drain pipe. Don't panic if the latex glove on the Dishwasher vent starts to "breathe" in time with the plunges.
If this clears the pipe, well done, don't forget to run water down the Disposal for at least 30 seconds to flush away the debris.
If it's still blocked you with have to remove the drain pipe and manually unblock it sometimes the connector from the Disposal pipe to the main drain gets blocked remember to check there as well. I've been an Maintenance Manager for several years and I've never seen a blocked Disposal drain chamber, it's usually in the pipework.
Good Luck.
Try this:
Good Luck.
y
