high whinning noise
  • vdotmatrix
    • Feb 2004
    • 314
    high whinning noise
    14 yr old agitator washing machine...makes a low level hign whinning noise on all cycles .....any ideads?
    It's sometimes better to be lucky than smart.
    ** 14 yr old agitator washing machine **
    That doesn't help a lot to identify the appliance in question I'm afraid. Of most help would be posting its brand name and complete model number off its identification tag.
    ** makes a low level high whinning noise on all cycles **
    On wash or spin or fill or drain, on all???
    ** any ideads? **
    If the sound only occurs when the motor is running (wash, spin, drain), maybe something is caught in the machine and rubbing when movement is taking place? Stray underwires from bras can do a lot of damage when they separate from a garment. Stuff can sometimes also get caught in the pump and result in strange sounds.
    I would strongly suggest you discontinue use until the cause of found so no additional damage will be done to the machine.
