I have a Frigidaire with a PureSource Water filter. I need to replace a cracked water filter housing. How do i remove the shroud around it? I only see one hex head screw that attaches it to the side.
How to remove shroud around water filter
If you post the fridge's exact model number, someone may be able to look it up and tell you how to go about it.
=D~~~~~~ -
That is only part of a model number, did you get it rught off the appliance's model and serial number identification tag? That is the only reliable place the complete model number will be found.Originally posted by arpModel number is FRS26ZRF
LINK > Model Number Tag Search
Some of the possiblie model's filter housing looks to be accessed using a wrench the way HayZee518's link described.
=D~~~~~~Comment
Thanks for the great picture. It looks just like mine. I need to replace the whole filter unit and I can't get the piece that runs across the back off to uncover the filter system. There appears to be one screw holding it but when I remove it, it doesn't come loose.Comment
Model number
I'm afraid I have never had to disassemble one one that far but if you post the fridge's complete model number, I'll see if looking at the parts it consists of gives me any clues as to how it might come apart.Originally posted by arpI need to replace the whole filter unit and I can't get the piece that runs across the back off to uncover the filter system.
=D~~~~~~Comment
By the picture of the part (see the following link), it looks like there are recesses for 2 screws to go through it, up into the ceiling? That is just a guess though, as I said, I have never needed to remove one myself.Originally posted by arp[Frigidaire refrigerator] Model # FRS26ZRFD3. I need to replace a cracked water filter housing. How do i remove the shroud around it? I only see one hex head screw that attaches it to the side.
LINK > Frigidaire FRS26ZRFD3 Damper Control Box Housing
I don't know if it will help but you can see exploded parts views of your model at this link:
LINK > Frigidaire FRS26ZRFD3 Exploded Parts Views
BTW. What is it that you have to replace in there, the part that the filter actually goes into (see the following link)? Did it break from freezing damage??
LINK > FRS26ZRFD3 Water Filter Housing Assembly (less filter)
=D~~~~~~Comment
