maytag dryer roller shaft floppy
  • william269
    • May 2006
    the lower roller shaft is floppy, at the point I stopped the braket is not assessable, can that braket/shaft be replaced or can the shaft be tightened?
    the shaft has a hex head on the back side
    More information...
    Originally posted by william269
    can that bracket/shaft be replaced
    Probably but without knowing the exact model of Maytag dryer you have (hint: read the following forum message), we couldn't say for sure. Maytag had sold numerous different dryer designed over the years, they're not all the same.
    Previous Forum Message > Please include Make and Model # in post
    JFYI
    • william269
      • May 2006
      Thanx, later that day I found the exploded view on Maytags site, tumbler had to come out, (that braket is part of a larger piece), hex nut on back of shaft, grab the non-bearing surface of shaft with pliers and tighten nut, reassemble, wife happy. two hours includes reasearch, no parts, w/o travel, I live here.
