GE Side/Side Icemaker still not getting water after replacing inlet valve.
  • clint
    • Aug 2006
    • 5
    I have a GE, Model: GSL25JFPE BS that is not making ice.
    The icemaker has the green light and will cycle through clearing out (for now) imaginary ice cubes.
    I've checked the hose from the ice inlet valve to the maker - no clogs.
    We get water through the water dispenser.
    I've replaced the water inlet valve (combo ice and water) thinking that was the problem on the ice side.
    Any suggestions of where to look next?
    Thanks for the forum by the way!!!
    As near as I can tell, you seen to have covered everything besides whether the icemaker is calling for water or not. Did anyone check to make sure the water valve for the icemaker was actually getting power when the icemaker should be filling?
    That should have nothing to do with operation of the icemaker... besides just letting you know that water is getting to the whole fridge.
    • clint
      • Aug 2006
      • 5
      Did I check for power when it's filling? no.
      Is it getting water? yes, but it looks like it released barely enough to fill a shot glass. just a shot of water to help loosen the ice from the tray, i wonder? don't know. i'm going to sleep on it and see if the ice cube fairy came overnight.
      Thanks for the help and quick response, Dan O.!!!! i'll try to pay it fwd!
      • clint
        • Aug 2006
        • 5
        *Update* - no water. Dammit.
          That is likely something that will need to be checked. If the water valve is NOT getting power when the icemaker is calling for fill, either the icemaker's internal switch for the water fill power is not operating or there may be a problem in the wire harness from the icemaker to the water valve.
          If the valve WAS getting power but the icemaker was still not filling, either the water valve was bad (unlikely IMO since you said you changed it) or the water can not flow though the tubing to the icemaker (which you said was not the case either).
          Released where? How???
          • clint
            • Aug 2006
            • 5
            PHP Code:
            how do i check if the water inlet valve is getting power?
            where's the icemaker's internal switch for the water fill?
            where's the wire harness?
            PHP Code:
            coming from the icewater line into the tray. If I turn the icemaker back on, it
            1. shoots about a shotglassful of water into the tray, then
            2. rotates the spindle to remove ice cubes from the tray and
            3. then i assume that's when the water should be filling the icetray but instead it does nothing. unless i turn the icemaker off and on again, which it will cycle through the same procedure.
              A test light or volt mater should usually be able to be used.
              Inside the icemaker. The icemaker used on your model is electronically controlled, the "switches" are likely part of a circuit board. AFAIK those icemakers are not serviceable. If they are defective, the whole unit has to be replaced.
              LINK > GE GSL25JFPEBS Icemaker Assembly
              Inside of the cabinet going from where the icemaker plugs into the wall in the freezer until it come out the bottom of the cabinet and leads to the icemaker water valve.
              ** Is it getting water?
              That is different than your original message title of "Icemaker still not getting water after replacing inlet valve".
              **Released where? How?**
              coming from the icewater line into the tray. If I turn the icemaker back on, it shoots about a shotglassful of water into the tray
              Someone will likely need to see if it's the power to the water valve cutting off or the water valve failing to stay open even while powered.
                anybody check the bail rod? if it is up (sensing a full bucket of ice) the water won't flow. if it is locked up water won't flow in.
                  Little bit of water
                  Good thought but the OP later corrected his complaint saying that some water was getting through to the iceamker at time of fill, but just a little bit. If the icemaker thought the ice bucket was full (resulting in the I/M bail arm being up), it wouldn't call for water at all.
                  JFYI
                    ok just a thought
