Whirlpool Washer Type 113-01, model LCR7244HQO washes and rinses, but does not spin to complete the cycle. I would appreciate any suggestions as to what can be done.
Whirlpool Washer won't spin to finish
What does it do instead? Stop right at that point (motor and timer too) or does the timer continue on to the end of the cycle just not spinning??Originally posted by RobGWhirlpool washer model LCR7244HQO
...does not spin to complete the cycle.
Does it drain?
Will it still agitate during the wash?Originally posted by RobG
It just does not spin.
Good.Originally posted by RobGYes, it agitates
Can you hear the main motor (not the pump motor) running/trying to run when it should be spinning?
Than there could be a problem with the lid switch not being activated, the electronic control or even the water level switch. I might look into the functioning of the lid switch first.Originally posted by RobG
it seems the motor is not on.
JMO
Whirpool washer ...
I ran it again and set it at minimum wash size. While agitating with about 1/3 the amount of water, it started filling it up. I stopped the machine and set it to drain-spin. I used a screwdriver instead of the lid and repeatedly pressed on the switch until the machine did spin and drain.
What does that tell us? The water level sensor?
Thanks for your help.
Rob
Lid switch?
If you have to fiddle with the lid switch to get it running, I would hazard a guess the problem is most likely in the lid switch or its actuation mechanism.Originally posted by RobGI used a screwdriver instead of the lid and repeatedly pressed on the switch until the machine did spin and drain.
LINK > Whirlpool LCR7244HQ0 Washer Lid Switch
If the problem was in the water level control, I wouldn't expect any amount of fiddling with the lid switch to alter operation.
JMO
