My freezer fan was making a noise and I took the indise panel off to expose it and noticed that there was ice build up around the fan causing the fan "rub" against the ice which causing the noise. I removed the ice and 2 months later same issue again! It's turned into a regular problem, every few mon ths I need to chop out the ice around the fan. Any Ideas?
Also, not sure if this would relate to my earlier post "water dispenser just trickles"
Brian
Brian
