Hi there, only think I can remember doing different is putting a lot of spaghetti and meatballs (leftovers) down the drain. When I went to use it later in the day it wouldnt drain the water, it backed up into the other side of the sink. Motor turns but only swishes the water around, after awhile the water goes somewhere (I am assuming drains) but then when you turn on the water it starts all over. I did the reset button, allen wrench, took apart the pipes running from the disposal to the other side but it looked as if nothing was stuck preventing the draining. Plumber coming over later this afternoon but hoping to fix it and cancel. Any suggestions that I have not tried?? Thank you much.
