I have a Maytag gas dryer, Model MDG7658BWW. It won't get hot. Any suggestions? I currently can't afford to hire someone to fix it. Thanks.
Maytag gas dryer won't heat
Ignitor glowing?
** It won't get hot. Any suggestions? **
If you want to try to fix it yourself a start will be observing what the gas burner's ignitor is doing when the dryer should be heating. Knowing that will help to narrow down the possibilities which will then in turn require further investigation.
=D~~~~~~ -
More specific description needed
Does the ignitor stay glowing continuously or cycle on and off repeatedly??Originally posted by Lauri
The ignitor gets hot but it doesn't light the gas.
=D~~~~~~Comment
How long is it on and off for, seconds, minutes, more???Originally posted by Lauri
The ignitor goes on but just doesn't light the gas. However, it doesn't stay on constantly
Sorry but I have no idea what could possibly cause all of your stated symptoms. As long as the burner is getting power (as evidenced by the ignitor glowing), its operation (glowing, lighting, etc.) should be consistent.it will light the gas when I put the control on delicate.
All the temperature control settings do is provide power to the gas burner mechanism at different temperatures. If the burner is getting power, it should be operating no matter what temperature setting the dryer is set to.
=D~~~~~~Comment
The ignitor doesn't light the gas all the time. I noticed that during a drying cycle the ignitor goes on and off without igniting the gas. The ignitor goes on for maybe 30 seconds and then fades away, without lighting the gas.Comment
Not igniting the gas but I hope not releasing it either.Originally posted by Lauri
The sequence of events should be; the dryer calls for heat, the ignitor glows white hot, the ignitor shuts off and at the same time gas is released into the combustion chamber. The released gas is ignited by the now slightly cooling ignitor. Once lit the flame stays on until one of the thermostats stops power to the gas valve.
The ignitor cycling on and off but the gas valve not releasing gas (nor producing a flame for obvious reasons) is often caused by a failing solenoid coil (see the following link) on the gas valve.
LINK > Maytag MDG7658BWW Gas Valve Solenoid Coils
Appliance411.com
=D~~~~~~Comment
On any heat setting, not just delicate? (not that it matters)Originally posted by LauriIf I let the dryer "cool off" between loads, the [burner] will light as it's suppose to.
Those solenoid coils are bad for working once or twice but crapping out as they get warm from use. Your latest observations does not change my opinion of them being a possible cause.
=D~~~~~~Comment
Here's an online parts place that, when you type in the appliance model number, the site will take you to an exploded diagram page. Here you can find the two solenoids. They are solenoid 7 and 8 - one is gas booster solenoid the other is main gas open. Prices are also on the page.
Appliance Parts From PartSelect | Repair Parts For Major AppliancesComment
Yes, it comes exactly as seen in the picture, both (2) solenoid coils. It quite possibly also includes installation directions.Originally posted by Lauri
The link you previously posted for the parts, do you know if that includes both solenoids?
=D~~~~~~Comment
Channel: Appliances
