Hi,
I have a problem with my maytag fridge (RTD2100AAL). The fridge when it is running does a good job keeping everything cool, but every day and a half to two days it stops running. After a little investigating I realized if I twist the little nob on the defrost timer until it clicks and twist the thermometor off and on the fridge turns back on. I did this in hopes that it would fix the problem but then a couple days later it happened again. So I figured my defrost timer was going bad so I bought a new one (Used, but in working condition), after replacing the timer it worked great again for 2 days and then once again it stopped working. Any ideas of what might be the problem because I am out of ideas?
Zach
Zach
