Hi
House I'm renting has an older Inglis dishwasher
model IEU37100. Never trusted it.
It overflowed and leaked onto the floor (and into the
heating vent, out the ceiling vent one level down, onto
2 monitors, port replicator, external hard drive
I suspect the float or switch. Float seems to move ok.
Ran another short cycle, worked fine this time.
I've read about removing the float to make sure the mechanism is not clogged up, but not sure how to remove it - do I just pull up until to gives?
I recall now the landlord told me to run just the short cycle, and not to press any of the electronic switches on the panel (altho he did not say why). Could running a longer cycle be showing up a problem where a short cycle would not?
Thanks for any ideas you have!
A.
)I suspect the float or switch. Float seems to move ok.
A.
