Water Heater Problems
  • rduchateau2954
    • Nov 2009
    • 6
    About a month ago my water heater wasn't making any hot water and I had to replace the thermocouple. Now I have no heat again. I tried readjusting the thermocouple again with no sucess. The exhaust is running, the pilot stays lit but the burner never kicks on.
    Any ideas?
    Thanks,
    Ryan
    how did you originally adjust the thermocouple? the bulb should have the flame almost impinging in the flame.
    • rduchateau2954
      • Nov 2009
      • 6
      What does that mean?
        the flame looks like it is divided in two. the thermocouple is supposed to be almost in the flame so it heats up.
        • rduchateau2954
          • Nov 2009
          • 6
          Okay thanks, I will keep messing with it. Is it common for a new thermocouple to fail?
            no a new thermocouple doesn't normally fail.
            • rduchateau2954
              • Nov 2009
              • 6
              I readjusted the thermocouple and the burner fired up. I went down to check on it and there was water on the floor. Enough to worry me. What does that mean? That was about two hours ago. It hasn't done it since but its never done that before and it worried me.
              Thanks again,
              Ryan
                Occasionally the T&P valve lets go and vents the pressure and "some" water on the floor. It then reseals itself. If it does it again replace the T&P valve.
                • rduchateau2954
                  • Nov 2009
                  • 6
                  Okay thanks. Well it looks like I am good to go. Thanks for your help everybody.
                  Ryan
                  Lol thanks HayZee
