Freezer Door Gasket
  • richard1234
    • Jan 2010
    Freezer Door Gasket
    I am trying to find a freezer door gasket.
    Freezer Manufactured by White Consolidated 09/97
    Brand Name "Rich Food"
    Model GFY21D9FW0
    SN. WB7390901
    I've looked a bunch to no success.
    Thanks,
    Richard W.
  • Kman
    • Dec 2009
    • 59
    Is this it?
    Part 510308 from RepairClinic.com
    • richard1234
      • Jan 2010
      Thanks KMAN
      The picture looks like it, I ordered it and will know for sure in a week.
      Thanks KMAN you ROCK!!
      • Dan O.
        • Sep 2003
        • 2167
        Wrong gasket ordered?
        Originally posted by richard1234
        I am trying to find a freezer door gasket [for a] freezer manufactured by White Consolidated 09/97
        Model GFY21D9FW0
        I can find no listing for such a model number. If the model number is actually GFU21D9FW0 (the "U" usually indicating an Upright freezer model) the following door gasket should be the correct one for it.
        LINK > GFU21D9FW0 Freezer Door Seal
        The 510308 gasket looks to be for a much smaller 12 cu.ft freezer as opposed to your 21 cu.ft. model.
        BTW. The link I supplied above displays its rough measurements to compare with the original.
        JFYI
        • richard1234
          • Jan 2010
          Gasket advice from Dan O.
          Dan O. You were correct regarding the gasket. I received the first gasket and it was about 2/3 the size I needed. I re-red my model number and it was a GFU and not a GFY. I also measured the door gasket (shoulda' done this first) and matched it to the gasket that you recommended. I ordered "your" gasket and installed it with-out a hitch.
          Thanks for your help
          -RW-
          • Dan O.
            • Sep 2003
            • 2167
            Fixed
            That's not usually necessary if ordered using a proper model number.
            Glad to hear it. Thanks for the follow up.
