I have a GE GSC23LSRC SS with the ice and water dispenser in the freezer door. The night light has worked fine until it burned out yesterday, and I replaced it with a 12V 6W bulb. The light slowly glows very light orange, and that's it. When turning off the light, the glow slowly diminishes. I tried the second bulb in the package and the same thing happened. How can a burned out light bulb cause something like this to happen???
Light in fridge door only glows light orange
Tags: None
GE says to replace with a 6w bulb, and the mounting clip says 12v 6w Max. It sure looks like that's what I installed.Comment
You are right...the 2-pack says S6S 12 volt. That's why I'm stumped. I put in exactly what was there before!Comment
Whatever caused the bulb to burn out could have damaged the electronic control that feeds the power to it. I'm not sure if that is the dispenser control board or the fridge's main electronic control. Someone might need to check the fridge's wiring diagram to see which might be suspect for your symptom.How can a burned out light bulb cause something like this to happen?
LINK > GE GSC23LSRCSS Dispenser Control Board
LINK > GE GSC23LSRCSS Main 'Mother' Board (on back of refrigerator)
JMO
=D~~~~~~Comment
