model number: GSD5911D01SS
serial number: FA601043A
Now that that is out of the way :^), my dishwasher has stopped draining and when the cycle is complete there is about 2-3" of water left in the tub (almost or even up to the heating element).
Full disclosure: I have been recently renovated my kitchen, and the D/W has been moved around a bit so I might have done something to it. As well, the water line that supplies the top washing arm was leaking and I bought and installed a new one about 2 weeks ago (at that point the unit was draining I think!)
I pulled the unit out and have run it many times on the rinse cycle to see if the water will ever drain with limited success (the levels are different but getting worse). However, I found the circuit diagram w/ testing functions sheet and ran the F-1 test cycle.... AND IT DRAINED!!!
I think I have found the aux pump on the right side at the back with the red and red/white wires. I put a voltage detector on the red wire and when the F-1 test called for the aux pump, my voltage detector beeped the whole time it was draining. Then I ran the rinse cycle and the voltage detector only chirped for a fraction of a second right before it was done.
I am confused!
Cheers,
-Dennis
I am confused!
Cheers,
-Dennis
