The problem I am having may be related to how much water in filling the bottom of the tub. My dishes at on the top rack are dirty when the come out then before I put them in, sometimes a lot of the soap is still in the dispenser and even though my water temp reads over 120 the HO flashes on the display many times during using the normal setting.
I think my dishwasher issue is a lack water pressure or low flow issue. The reason I say that is because I have trouble using lawn water sprinklers and if I check the pressure on one hose spigot, while the other hose spigot is on I get a drop from 62 psi to to 42 psi. Does this kind of drop sound normal? What GPM does my dishwasher need or how long should the fill timer run for my model? Thanks for any help you can be.
