kenmore washing machine sits cockeyed at top
  • ba_50
    • Mar 2008
    • 142
    The model number is 110.28812790. The tub seems to just sit on #17 and #17 isn't fastened to the base #19. The tub seems to bounce around especially at the top during the spinning cycle.
    We don't have a clue. Thanks.
    Washer moved??
    That is correct.
    Was the washing machine relocated or tipped on its side previous to this occurrence? If so, that triangular 'skid plate' may now be out of position.
    • ba_50
      • Mar 2008
      • 142
      It has been somewhat out of balance for a year and today a heavy load may have made it worse.
      We tried to line position it upside down but it won't stay put. It looks like the front, back, wires, and everything has to be taken apart to fix it.
        The whole washer?? Don't do that!
        The washer's cabinet comes off for service, yes. You can read about that and positioning the triangular skid plate at that following link. Someone can investigate the suspension springs at the same time.
        LINK > Washer moves around too much:
        It might have been a good idea to have it looked into at the time before it got worse and/or caused more damage.
        • ba_50
          • Mar 2008
          • 142
          Don,
          My brother was really impressed with the instructions you sent. We got it working ok with a medium load and if it gets worse we will take it apart and roughen up those pads.
          We do have a Maytag LA612 that needs a use clamp at the top of the barrel. If we find one the other one gets pitched.
          Thanks. Bob
            Washer tub clamp
            Maytag LA612 needs a use clamp at the top of the barrel.
            That part looks to have been discontinued but the web site at the following link says they still have one in stock:
            LINK > Maytag LA612 Tub Clamp
            JFYI
