Sansui VRDVD4005 Recorder
  • lindon105
    • Nov 2011
    • 10
    My Sansui VRDVD4005 does not accept VHS tapes. It will either reject a tape after loading it or will not let the tape be fully loaded. IFIXNC said it can not be repaired. I'm not ready to junk it yet. Any suggestions?
  • lindon105
    • Nov 2011
    • 10
    Never mind, I fixed it! There was a foreign object inside.
    • lindon105
      • Nov 2011
      • 10
      I've run into another problem!! The remote will control all functions except the set up menu. When the button on the remote is pressed and the set up menu appears , nothing happens when the down arrrow is pressed to make a selection. I've unplugged the unit for several minutes, but this didn't correct the problem. All other functions work ok with the remote except for this problem. Any suggestion for what I try next?
      • lindon105
        • Nov 2011
        • 10
        I'm now able to navigate within the set up screen, but now another problem has developed. When I press the "dubbing" button nothing happens. The manual states a yes/no record message should appear, but it doesn't. I'm trying to dub a VHS tape to a DVD. Any ideas what may be causing this problem?
          inside the remote are thin film tactile switches. each button has a carbon slug that makes and breaks a connection on the film. you could try cleaning the thin film with a pencil eraser and or alcohol and a q tip.
          • lindon105
            • Nov 2011
            • 10
            What is the best way to pry the remote open? I tried with a knife but was reluctant to apply much force for concern about breaking something.
            • lindon105
              • Nov 2011
              • 10
              I was able to open the remote and I cleaned the film, but it didn't fix the problem. All other functions work ok, but still can't dub.
              • lindon105
                • Nov 2011
                • 10
                When I press the "dubbing" button on the remote, the LED lights up, so I don't think the remote is the problem. It must be a problem inside the recorder. Looks like future dubbing will have to be done on a new unit.
                • lindon105
                  • Nov 2011
                  • 10
                  Even though the remote LED lights up as I describe, could the remote still be the cause of no dubbing?
                    only way would be to purchase a universal remote with the same characteristics as yours. chances are two remotes couldn't be at fault. could be the logic board in your unit.
                    • lindon105
                      • Nov 2011
                      • 10
                      I ordered a new remote from Orion (Sansui) . It's returnable if that's not the fix. I'll post the results.
                      • lindon105
                        • Nov 2011
                        • 10
                        A new remote did not fix the problem.
                        • homepage
                          Banned
                          • May 2012
                          The LED light up, so I don't think remote is the problem. It must be a problem,,,,,,,,
