My Sansui VRDVD4005 does not accept VHS tapes. It will either reject a tape after loading it or will not let the tape be fully loaded. IFIXNC said it can not be repaired. I'm not ready to junk it yet. Any suggestions?
Sansui VRDVD4005 Recorder
I've run into another problem!! The remote will control all functions except the set up menu. When the button on the remote is pressed and the set up menu appears , nothing happens when the down arrrow is pressed to make a selection. I've unplugged the unit for several minutes, but this didn't correct the problem. All other functions work ok with the remote except for this problem. Any suggestion for what I try next?Comment
I'm now able to navigate within the set up screen, but now another problem has developed. When I press the "dubbing" button nothing happens. The manual states a yes/no record message should appear, but it doesn't. I'm trying to dub a VHS tape to a DVD. Any ideas what may be causing this problem?Comment
