I am looking for the best all-in-one software available in the market (not a compilation of multiple freeware programs). I understand that DVD X Copy is the best ever, but states that it is no longer available. This DVD Copy Software review site: has some good info, but which one of these is best?
What is the best DVD copy software?
I use two apps. First one to start with is dvd backup. You can get it for free on Versiontracker site or the. This app strips the dvd down into a file with the encryption and region code removed. If the file is smaller than 4.7 gigs you can them burn directly to a dvd. Ifnot, usually the case with newer dvds with loads of extras on one
disc... you'll need a second (not free) program. DVD2onex. This app breaks the file down into chapters. You select the longest (the movie) and process that into a smaller file that can now be burned onto a dvd.Comment
I had the same problem before.
I chose *******, because it does not have audio and video do not sync, I just like this.
I always use ******* Blu-ray DVD Ripper.It is very cool and easy to use . I have used it many months.I also have some problem,but the FAQ of ******* and the after-sale service is so good!
if you want more info ,search ******* by google
good luck!Comment
YES, i tried. Its wonderful audio and video sync tech satisfys me very well.I had the same problem before.
good luck!Comment
******* Blu-ray Copy is top-ranked and easy-to-use Blu-ray utility for users to make complete copies of DVD and Blu-ray movies. It allows you to protect your investments against damage caused by scratches or frequent use. With this program you can burn Blu-ray and DVD movies directly to Blu-ray discs and DVDs, copy them and save as folder or ISO image file for your movie collection easily. It also enables you to burn existing Blu-ray folder or DVD ISO image file to blank Blu-ray discs, and convert Blu-ray folder to ISO image file. The fast copying speed and friendly user interface make Blu-ray copy easier than ever. You may rename the volume label of target disc and set auto shutdown during copying as well.
With ******* Blu-ray Copy you can:
1. Make perfect 1:1 copies of Blu-ray and DVD movies
2. Support disc to disc, disc to folder, and disc to ISO backup to meet your multiple needs
3. Copy Blu-ray and DVD movies with flawless quality
4. Free you from the annoying protections of Blu-ray and DVD movies
5. Directly burn Blu-ray and DVD movies without other burning softwareComment
I use anydvd and clonedvd by slysoft. I have never had any problems with it at all. Any CD is great as well. This is for CD's such as karaoke types, or VCD. I love it.
Thank you, it works well for me.P.avtube Blu-ray Copy is top-ranked and easy-to-use Blu-ray utility for users to make complete copies of DVD and Blu-ray movies. It allows you to protect your investments against damage caused by scratches or frequent use. With this program you can burn Blu-ray and DVD movies directly to Blu-ray discs and DVDs, copy them and save as folder or ISO image file for your movie collection easily. It also enables you to burn existing Blu-ray folder or DVD ISO image file to blank Blu-ray discs, and convert Blu-ray folder to ISO image file. The fast copying speed and friendly user interface make Blu-ray copy easier than ever. You may rename the volume label of target disc and set auto shutdown during copying as well.
With P.avtube Blu-ray Copy you can:
I find myself doing the same thing, make a copy of the disc with a ripper like DVDdecrypter, then break out the actual video you are going to keep (usually just the main movie) using DVD Shrink or Nero Recode.
I don't know of any application that always works and it's so frustrating figuring them out that I just stick to the two step approach.
