I have ordered T5 light fixtures for my metal building which have universal voltage ballasts that will accept 110 to 277 volts. The guy I ordered the fixtures from said the lights would use less current if wired for 220V. Can someone explain this?
Shop light wiring
other than efficiency there would be no other reason to use the 277 tap on the ballast. a three phase service 120/208-277 would be needed for 277. voltage of 220-240 wouldn't save you anything. you'd actually measure 277 volts to the neutral with a meter.
Well my light fixtures were finally delivered and I hung and wired them yesterday. Initially they were on 120V, but today I added another breaker and moved the neutral and marked it appropriately. Now the lights are running on 240V. Yes, the electronic ballast auto-detected the input voltage and my light switches were HD switches from Lowes that are good to 277V.
If nothing else, it's different
. Thanks HayZee518!
I was going to post pictures but..."You are only allowed to post URLs to other sites after you have made 15 posts or more."
Well it would depend on the ballast. Here is the spec sheet for the ballast used in my lights...http://www.ace-ballast.com/articles/...-A2_54T5XS.pdf
